New to the forum
HardDriveRandy
Location
Maine
Like to introduce myself. I have a 2025 CanAm Defender Limited HD10 with 3500 miles also having problems. Check engine light P0301 and P302 shortly after fueling up yesterday. Hopefully it’s bad fuel but I had 2 other SXSs with me and they didn’t have any trouble. I’ll find out today I’m going to drain the fuel out and put fresh fuel. Last night checked my fuel pressure and it was 53 psi which I believe to be normal from what I can find on internet. It also holds pressure good and while I was at it I had a new sock to put on it as I had changed last year and I had bought a 3 pack from Quantum. The one I took off was a little dirty but I really don’t believe it’s the problem? Funny part is it will run fine in eco mode but eco off or work mode soon as you come on to it 1/2 throttle or better it will misfire and if I hold it wide open it will go into limp mode. I had to shut it off and restart it and it would run fine till I hit half throttle again. I will post if I figure it out but any insight would be greatly appreciated Thanks
