Resetting "Maintenance Required" Message
You would think that BRP could figure out an easier method than this, LOL.
I’ve tried so many times with no luck. What a joke to even have this as a way to clear codes. Might get the buds software just to make some extra money on the side cleaning codes for guys. So stupid.
Holy S button I got it. Felt like I hit the lotto when it flashed my defenders name then no maintenance message. Still such a dumb system. I got to thinking about the issue stated by others that you can’t get to high without passing low. This was my prob I think and maybe others also.
put the machine lights to low before I turn key
then turn to accessories but don’t start
Hold down the s button wile on total mileage
do the hi low hi low hi low but stay on low
release s button and shut key off all wile still on low
wait for total shutdown
that’s what worked for me. My defender has both s and m buttons so not sure about others that only have one single button. I never use those lights so never really thought about the starting with them already on low. Hope this helps a few others.
Have the same problem, only 1 button on the display. Tried this several times and ways. Talked to the dealer and he said only way to clear the "maintenance required" is to take it to the dealer and they have to clear it....just changed oil and new spark plugs, 1023 miles and 212hrs. Probably came on at 200 hrs. 2018 Can-am defender Max HD8
I can’t speak for the single button models as I’ve got the duel but I was also told by a stealership that I couldn’t do it without buds. Just another thing they got wrong. Glad the fine folks on this site can outperform the dealerships lol
I have a single button model and I had to get creative to get mine to reset.
then turn to on but don’t start
Hold down the s button while on mph/rpm screen
I couldn’t use the total milage/ OD or it would change my mph/rpm screen. I hope this is helpful
This worked for me 2016 hd10.
It had to be the MPH/RPM screen.
Each time I tried on the OD it would change from that to the MPH/RPM screen after holding the set/mode (I only have 1) button for about half a second.
