rob119021
A rat chewed a hole in the coolant line from the front radiator to the motor area in my 2021 Defender HD8 Max XT. I can feel one hole in the elbow right in front of the motor. I can see some wires that were chewed under the battery area. My CanAm is running rough at startup. I repaired a wire into my muffler area that had given me a P1130 code and engine light and that went away. I also have a wire to repair for my left side high beam. I need to access the area under the rear floor deck and above the skid plate under the battery area in front of the motor. Before I start removing panels, is this area accessed by removing skid plates or removing the floor access panels in the back right passenger area.
