My 2018 HD10 XT Cab has a 3" lift (pucks) and I'm running 30" terminators on stock length axles without them popping out... Just the odd breakage...Hey I have a 2019 xt cab model as well. I am having lots of issues with the front diff and wanted to see if you guys know the correct axle length for the front axles. My bike has a 3 in catvos lift and has gorilla axles in the front. I'm starting to wonder if my front axles are the wrong length. The front right will pop out and if they are both seated in the diff I have lots of popping when turning. Figured I would verify lengths first.
Unfortunately GSP Doesn't t list the specs for the front left (4102050 or 4102045) the same way
Front Right stock axle specs from My GSP replacement Front Right (4102044) which matched my stock (Can Am 705402170) axle perfectly.
Front Right (GSP 4102044)
Axle Nut Included
Yes
Axle Nut Length
1.08
Axle Nut Socket Size
30
Axle Nut Thread Size
M20X1.5-6H
Axle Nut Type
Castle Nut
Boot Color
Black
Boot Material
TPE
California Proposition 65
Yes
Compressed Length
29.8
Dynamic Damper Attached
No
Extended Length
31.69
Inboard Joint Type
DOJ
Inboard Spline Quantity
21
Outboard Joint Type
BJ
Outboard Spline Quantity
29
