Windshield Washer pump fuse
Booter
Does anyone know which fuse and which fuse box handles the windshield washer fluid pump on a 2018 Cab XT? Hoping for a little direction before having to pull every single one, no information in the manual. Pump quit, plenty of fluid, no vacuum, just no juice.
The fuse box under the front hood has a 40 amp fuse F10 off to the side and if the switch is not illuminated try removing the inside panel for the windshield wiper it may have its own fuse near the terminal block?
Thanks! The fuses in the main box are ok, will look at pulling the interior panel to see if it might be there, or a loose connection, or maybe just a dead pump!
I would check the switch mine has failed twice and have new one on the way again this week. The switches on these units are poorly made.
