You might have to ask your dealer, I looked at my 2019 and the wiring from the winch heads up towards the front fuse box. I didn't raise the machine to see if it is visible from underneath but I suspect it may be visible when you remove the front hood and the side plastics?
I will be adding a rear winch to my machine and it looks like there may be just enough room for the solenoid in front of the starter solenoid next to battery on the floor? Haven't measured that area to confirm yet? FYI
