I agree with Andy. As long as your trailer can handle the weight and you have enough weight on the tongue of the trailer, its fine. One draw back to having such a tight trailer is when you go to tie down your machine, you're basically running the straps straight down and when the straps are straight down they have more of a tendency to unhook as the trailer and machine bounce down the road, but if you had tire nets that problem is solved.
