The 3 mode switch doesn't have a huge response but when you click the guage you will see the mode scroll across your screen, the reason I suggested the work mode is because it tones down your foot pedal response to reduce jerkiness when going over uneven surfaces. If you feel that the work mode doesn't affect the surging it may be something that requires a trip to the dealer to see if you have an accelerator code, fuel pressure etc. or if a spring or clutch button has broken in the CVT secondary? It might even be a faulty spark plug, injector etc. which the dealer should be able to find. Good luck.
