I have an 2018 hd10....box squeaks like crazy. Still squeaks when tilted up in dump position. Push left to right on pivot bar and that is where it comes from. Anyone else me experience this? Did you find a way to correct. No way to grease it??
Try lubricating the pivot points (bushings) with a silicone spray or something similar, you might be able to get some grease in there with a grease needle?
You can get Steel bed mounts for the box that replaces those plastic ones that can am thought was a good idea. I’m pretty sure battle armour makes the. I plan on doing this but probably not till one breaks. Grease or oil might stop the squeak but will only help dirt stick around inside. Maybe try taking the bed off and cleaning/inspecting them first. One could be cracked.
