Sound Bar
PCB2054
I want to put the bazooka sound bar in can am defender max xt hd10 and wanted to know if anyone knows where accessory power is easily located.  I’d like to only run it when key is on and I think there is an easy way to do it but I don’t know how yet.  Anyone ever tackle this before?  Please let me know. Thanks everyone.
There are several threads on here in the garage builds section check it out. On the 2020 and the newer ones there is a terminal strip under the small hood panel. In the enclosed cab models there is a terminal strip under the roof liner. You can remove the black metal panel in the front to get access to this area and you can mount the switches in the knockouts on the panel.🙂
I ran mine straight from the battery for ease of installation. I was always worried that I would forget to turn of the sound bar, but luckily, I never did.
Welcome to the forum @PCB2054 - Check out this thread for good information on using the terminals to install the soundbar
