You
I have a 2021 can am defender and was wiring into the factory light switch to turn on a light bar relay on when the high beam was selected. I accidentally grounded out on the negative terminal and killed the fuse. I replaced the fuse and the lights work but all the switches Do not illuminate and the icon on the display panel will not show which mode you are in. All 4 tires are show to be engaged but the switches work to changes from 2 to 4 wheel drive. All the fuse are good. Need help on getting the mode back on the display panel. Could it be an internal fuse in the light switch???
