S3 Powersports Defender HD Springs
The S3 Power Sports Can-Am Defender HD Springs are engineered with performance and functionality in mind. These Heavy Duty springs are designed to increase your load capacity and decrease suspension "sag" you get with factory springs. You will also improve vehicle stability with the increased spring rate and, in many cases, increase ground clearance. If you like to work hard or play hard, our Can-Am Defender HD Springs are a necessity.
Extreme Duty (ED) Springs: A "stiffer" alternative to our HD Springs, Extreme Duty Springs are ideal when managing exceptionally heavy loads.
These springs will now work on the front of the 2019 XMR, Lonestar and Cab models!
More information can be found here: https://s3powersports.com/s3-power-sports-can-am-defender-hd-springs
A good option for those who use their Defenders to go out hunting. I saw a lot of pictures this year with some big bucks in the backs of peoples Defenders.
