Rocker panel switch
Phil D
Hey,
I have a 2020 Defender HD 10 Mossy Oak and I want to install a 3 mode switch for work eco and normal modes. I pulled the cover off the panel and the only available plug says POS # 6 on it.... I plugged the switch in but it doesn’t seem to do anything.... anyone know what that switch plug is for and if there is one for the 3 mode ... I’m stumped.
I can look in my manual. But unfortunately it seems from 19 to 20 things changed... I  find that in reality... my switch (OEM INSTALLED) is a PITA... If I had Grandkids sure maybe... being able to drop Bear into "work mode" would be nice... But as it is now.... ECO is a joke... (I would have saved money and bought an HD 5 if I wanted a snail) And work mode??? I just make sure I'm in LR when working him hard....
Maybe others could chime in whether or not they actually use their mode switches or not???
Why do you want a switch? the 2020 defender has the switch built in to the display buttons....Work mode is nice if your going slow around the house, it dosen't jerk as much on the clutch. ECO is decent if your cruising around town at 25mph max, its rather gutless when you take off in ECO.
