Wanting to remove inside door panels so I can clean it out and lubricate. Where can I purchase the plastic clips that screw in and what else is needed to remove panel
You can buy the push pins from Can Am or from an auto parts store and they are easier to remove if you have the tool which slides under the edges and helps pry the pin out. If you don't have the tool you can use a flat blade screw driver and pliers to get it out.
I recently had the bottom of the door panel off and it does collect sand and mud if you get into the deeper stuff but nothing down low to maintain. You can spray the door lock mechanism with a spray lubricant through the latch opening.
