Passenger door window switch failed twice
Greta
I have had to replace the window switch on the passenger door twice. It will work when I install a new switch for awhile then it fails can still operate from the drivers side. 2017 hd10 max
it seems to be a common problem with them, even on the newest machines.  I dont have one with switches but would think a differnent brand might be better or at least cheaper than the OEM switch.  Does it get wet or something? maybe it can be sealed off better or have a silicone cover of some sort to shield it from getting gunk in it.
My suggestion is to try to find a different brand of switch from some other mfg.
https://www.amazon.com/Compatible-2016-2019-2018-2019-710004979-705800048/dp/B09T67Z9DB/ref=sr_1_11?keywords=can+am+switch&qid=1661784337&sr=8-11
