P0301 & P0302
travD49
Location
New York
I have a 2022 Defender Max Limited HD-10 and have been intermittently experiencing both P0301 and P0302 fault codes at the same time, which puts the machine into limp mode. After shutting the unit off and restarting it, operation returns to normal. However, after riding at a steady speed for some distance, then slowing to make a turn and reapplying throttle, the engine begins to misfire and the codes and limp mode return. I have found several forum threads describing this exact issue, but none include a confirmed solution—only others reporting the same symptoms. The spark plugs have already been replaced. Any insight or guidance would be greatly appreciated.
