Not much info to go on but two things come to mind: fuel or ignition. When you turn on the ignition do you hear the fuel pump start pressure up and stop? If not it may be a fuel pump issue? Do you have any codes? If you feel the fuel pump is good than you might want to remove a plug wire to see if you have spark when someone spins the engine over and if you remove the spark plug is it wet or dry?
