I have a 2020 limited under 1k miles and my shocks have started make an irritating noise and the brake are load at times has any others have this problem and what’s the fix
There are several threads on here about noisy brakes, as far as the shocks:
1) Check the sway bar bushings and lubricate with a spray lubricant or use a grease needle to get some grease in the bushing that should reduce the squeaking.
Brakes are embarrassing. Really, really disappointed. Nonstop squeaking when breaking and turning. Maybe these fancy POS’s aren’t meant for dust and dirt.
