Need some wheel/suspension help
Spitz
I have a 2019 Defender HD5, it’s completely stock and used for work around my property. Stock suspension stock tires. Need some more ground clearance but not looking to”trick” it out. Looking to possibly increase tire and rim size. Lookin for suggestions recommendations without completely redoing the suspension.
Check out the builds section, there will be some useful info there. You can get more clearance by cranking your spring adjusters to max. You can go to larger tires, also in the builds section without changing rims.
Be aware that taller tires will reduce your performance a bit because of more rotating mass and taller gear ratio.🙂
