Friend has a HD10 Max. Same exact symptoms as yours. Replaced fuel pump and fixed it!I also got a code that says to lean fuel..probably should have mentioned that... so not enough fuel mixing with air...fuel pump bad? map sensor?
good to know ,thanks
