Seems the defender limited sits a little low in rear. Maybe just needs an inch. All I could find is 2" minimum lift kits. Or could a guy shim between bed and frame?
You can start by increasing the tension on your rear springs, this is free, easy to do if you jack up the rear end and use the wrench. Check out the operators manual.
