Help me find
Swaybailey
Someone tried to hotwire my 2019 Defender Max.  In the process I think a diode got fused.  Had to replace the ignition switch because they jammed a screwdriver into it.  Now when you turn the key from ACC to On it cranks automatically.  The hot wire to the starter solenoid is always hot.  Can someone tell me where the 2 circled diodes in this diagram are or if I have come to the wrong conclusion?
