Help. 2019 Defender HD10 XT Has no power to head lights, winch, and dash.
LarryB
Drove my Defender for 2 minutes up to the house.  Turned it off.  Went to start it 10 minutes later and there was no activity when I turned the key.  Dash did not respond, headlights will not turn on, winch is dead.  All fuses seem to be good.What do I need to do?
My guess is that you have a loose connection to the battery, probably a corroded ground wire. If you have a volt meter check your battery first for 12.6+ volts first and if good start checking the cables and ground wires.🙂
My rooftop light is working just fine so I don't believe the battery is the problem.
Anyone have an idea?  I'm thinking that it might be one of the relays but no idea which one to check or how to check.
