Hey All
I have a 2018 Defender HD8 DPS. Running stock with the 14" Maxxis Bighorn 2.0 tyres
I recently purchased a weed spray unit that sits in the rear tray. Weights about 500 kgs when full of liquid, which maxes out the capacity of the Defender. It's created a few challenges - keen for advice on best way to improve.
1. The rear sag. Improved by adjusting rear suspension to highest (stiffest) setting.
2. Understeer. The heavy weight on the rear has created less traction on the front wheels, creates some under steer. Not sure how to fix?? PS: I have the front suspension on the softest (stock) setting.
3. Stability. The additional weight and increased centre of gravity feels like there is greater chance of a rollover on hilly terrain.
- Would wheel spacers help with lateral stability? Can I keep the stock wheels if I do install wheel spacers?
- Should I add a counter weight to the front to help with front/back stability? This may help with understeer issue too - but also concerned it will overload the vehicle?
