As for the condensation during storage... I would get ether a dehumidifier or a couple "dry air"s that you can get for an RV... If the dehumidifier.... just put in the conex... if the RV models... put in cab of SXS...When it works its as good as it gets. odd that everything else works but you can't even select the heat function. when you turn the a/c control to 80 you still don't have no warm temp coming thru vents. storing in a con-ex container/garage and I am noticing a humidity problem. water on dashboard, window, steering wheel. Is this gonna ruin all electronics?
