HD10 Limited door latch
Kevin082071
Just noticed that the top screw on the interior driver side door is gone and the latch assy seems to want to pull out.  Would anyone know where I can get the replacement screw or if I will have to replace the whole latch assy?  If so, is that covered by the warranty?
Thanks
probably best to pull the one out of the other side and take it to a do it best or other hardware store and try to match it up.  its going to be metric most likely, machine screws are probably going to be the best match being black if you can find them.  get 2 so you have a spare for next time if you need it again.
