HD10 engine issues
Mossyoak
Wondering if anyone out here has had any ongoing engine codes/limp home issues, my 2019 HD10 hunting edition has been to the shop on 3 separate occasions with the same 3 codes, P160E, P060E and P1613. First trip, dealer change air filter, 24hrs later back at dealer, they then changed throttle body, now 1 1/2 months later their changing the ECM
YIKES!!! That doesnt sond good. But I would take pictures of codes each time. If it persists LEMON LAW CLAIM!!!
GOOD LUCK!!!
Unfortunately I live in Canada and to my knowledge we do not have a Lemon Law here
No lemon laws in Canada but you could contact BRP care and ask them to open a file on your machine, I am not sure of the exact email address but I now they monitor the skidoo website and have reached out to owners with problems?🤔
Sounds like they are just replacing the parts involved with the error in order of cheapest to most expensive to replace.  Given those error codes they likely fixed it.  Only thing sounds like they didn't change was the electrical harness between ECM and the throttle body.  Hopefully they got it.
They said they pinned out the harness and it tests good, either got humidity at the ecm plug or in the ecm.
just wondering if you got all your issues sorted out.  I have a 2020 Defender throwing the same codes as well as P1615.   Mine heads to the shop in 2 weeks.  Hopefully I can figure it out before it goes there
I’m glad to say it has been trouble free for a while now, dealer said it was a loose ground wire at one of the plugs
my 2020 defender is showing the same code P1615.  What was the outcome?
