I have a 2018 defender lone star.. started running sluggish the other day and gradually got worse . Did some research and believed it to be the fuel pump strainer . Replaced strainer and now engine won’t crank .. tries to turn over but won’t crank . Pulled fuel lines from injectors and getting fuel to that point . Pulled injector and it looks normal , no build up from what I can see . Pulled spark plug and it seem d pretty dry for as many times I tried to start it . Tried starting with plug out and only got air coming out of cylinder , no gas ?
