EPI clutch kit question
Mndefender
Installed a EPI Mudder clutch kit on my HD8 xt cab with 30” tires. Used the green spring as recommended in the instructions. I have to say I don’t notice much of an improvement. Acceleration not any faster, top speed the same but less power at upper speeds. There seems to be a little more torque on initial take off, but it’s so indiscernible I’m not even sure that’s really improved either. Anybody have any thoughts?
are the rpms higher at any given speed?  say 40 mph, stock vs clutch kit.  i had a clutch kit in mine and really had the same thing, even with my hd10.  these are just big machines to try to move, its not going to make a huge difference.  i took mine out, the increased rpms while cruising made the cab even louder for running on the roads.
does it come with a helix as well?  if the green spring is indexable on holes, it may need to be adjusted to a tighter hole for more engagement.  not sure how that kit works, as i have an aftermarket assassins kit for mine.
What 30” tires are you running? Some are tremendously heavy. I added the same setup in the hd10 with 30” carnivores and mine will literally break ground from a dead stop to full throttle. Absolutely improved my performance. I would think the hd8 is just less hp and just not going to be that much of an improvement like you’re experiencing. May try a tuner. I run a power vision 3 made by dynojet.
