Dome light and windows
Chris1009
Dome light won’t come on and window switches wont work. The window switches won’t even light up. I replaced them both both at one point and have sanded and dilectric greased the contacts numerous times and they just keep failing, now the dome light wont turn on? Anyone else experiencing these issue’s on this 25,000$ POS. It’s just one tiny thing after another it seems!
They both pull power from the terminal behind the front header panel. The wire to that terminal runs down the driver's side to the power terminal under the dash in the center. I'd start there if both windows and the dome aren't working. Can't remember if there is a fuse up there or not, been awhile since I was up in that area.
