I have a 2020 Defender HD8 and am wanting to put a blinker kit that wont break the bank. What do you guys suggest for a brand? Have any of you guys put a signal kit on yours? Would like one that is plug and play to use my tail lights.
Link? I was thinking about adding a Jeep blinker arm to Bear... I HATE the rocker switch for the blinker...I went with the Wyco unit as it had an actual turn signal arm that mounts to the steering column. It also didn't have a "module" that would interfere with the storage under the drivers or middle seat. The Wyco unit also talks to my turn signal indicators in my 2020 limited dash so I know when they are on and I forgot to turn them off. The Wyco unit utilizes the rear tail lights as turn signals and gives you 3 blinkers on each side up front. I believe the Wyco unit might not be as plug and play as other manufacturers but it is the intuitive unit to use as it is just like your cars turn signal except you need to cancel after the turn. It also has a horn button on the end of the turn signal arm that is easy to use without having to reach to the dash to turn or run the horn. Best unit out so far.
