Defender limp mode
Jeff
I am thinking about buying a 2021 defender HD10 limited.  I have seen a lot of negative things online about issues with the machine.  Mainly going into limp mode and multiple trips back to the dealer for service.  Is this a wide spread problem with the machines.
I have a 2019 Defender XT Cab HD10 and had a loose drain plug from the factory. Other than that no faults or codes.
Some of the 2021 with A/C had problems with the A/C system, otherwise the number of problems that you see on line may be exagerated as some posters tend to post on multiple forums. Bottom line is you will have to make your own decision.😉
