I have a 18 HD10 and I've had a few issues with it over the years but this year it's getting hard to start.
I've changed the fuel sock a few times, do it every oil change now because I've had issues with that but this fall it started having issues with starting.
When it would fire up, you had to let it warm up at least 5 minutes or it would want to die when you moved it. Even if it was 80°.
Now it's below freezing and it is taking forever for it to fire. It cranks good but I have to crank on it for a few minutes(intervals of about 10 seconds then letting the computer shut all the way before going again) before it'll fire.
I'm leaning towards a fuel pump but once it's running it's working good so I hesitate on just buying one because all the fuel pumps I have dealt with are usually just dead. Any suggestions?
Also, my dealer told me to not use any type of block/engine heater but it really needs something, anyone have anything they've used?
