Can am defender limited
Kelseypfeiffer1988
I have this defender with a 40 inch rigid light bar on top and some rigid pods on back when they put the lights on at the dealer they connected them to the bus bar in the roof where the electric windows and the radio connect.  I was driving the other Night and lost all power up there anyone know where the fuse or relay for they top power is?
Look for a 40 Amp fuse under the hood on the front. If that one is good check out some of the others. ☺️
I don't know what model of Defender you have but under the front hood fuse box 1 is located and F10 is a 40 Amp fuse that provides power to the accessory output, the other fuse F2 is also 40 Amp and it provides power to the DPS. They are covered by a black cover which you must remove to see the fuses?😉
