Dan
- Jan 20, 2019
- 36
- 15
After 60 hours on my Can-Am XMR I have started to develop a bad brake squeal on my rear brakes. It sounded so bad I had my mechanic check it out because I swore I had a faulty wheel bearing or needed to use a greaser tool to lube my bearings again.
If you have experienced this it sounds like metal on metal so bad you swear damage is occurring every time it happens. Mine only happened in reverse at about 3-5 mph. The bearings appeared to be just fine upon inspection so my mechanic swears it’s a brake issue.
Apparently this is fairly common with Defenders and Can-Am in general using metallic brake pads. Has anyone experienced this? What did you use to fix it with real results?
