Anyone use Highway all terrain tires on their HD10?
TheJokerOK
I have the 14” factory wheels and wanted to put some all terrain highway tires on since I travel probably 85% on the pavement to the marina. Hoping someone has done it and knows the size that converts for the rims.
Check out the builds section in the garage and you should find what you are looking for.😉
could always use something like an STI x comp, they fit a 14" rim and are great tires for on road use- they wear like iron.  I have probably 1000 miles on mine on gravel and black top without any signs of wear.  they are also low pressure rated tires for off road use applications where it is applicable.
I have 2022 Defender/ I got rid of my stock tires and bought same tires that comes on 2023 Limited Defender/ Big differences
I have found that you will have a lot more DOT approved all-terrain tire options if you go with a 15-inch wheel.
I use Quadboss QBT846's (30x10x14r) and run a bunch of tar and gravel roads. Somewhere around 2000 miles, and solid still. 8ply radial, says DOT compliant but still an ATV tire on 14" stockers. MN for awhile was handing out fines for DOT certified LT tires on SxSs as our ATV definition stated 3 or more low pressure tires. So this was a way to skirt that. Not sure if they overturned that law, but I know they paused enforcement last year while they worked it out.
