ALL-NEW Apache Backcountry LT Track Kits and ProMount Plow Lineup
Last evening in Dallas, Texas, the Can-Am team announced a new line of accessories especially for winter and cold-weather adaptation, including all-new snow-specific track kits and a snow plow lineup.
Check out the videos below and the official press release soon to follow:
Below is the official press release:
TERRAIN IS NO LONGER THE LIMIT
Apache Backcountry & Backcountry LT track kits: EXPLORE WITHOUT COMPROMISE: Finally explore winter with no traction limitations and no compromise, thanks to the unmatched performance of Apache Backcountry track kits. Engineered to thrive in the deepest snow—for work or play. Don’t let winter stand in the way. Ride on untouched trails, traveling deep into winter’s embrace and you’ll know: the same technology behind our world-renowned Ski-Doo snowmobiles is at your command. With a larger contact patch, and more aggressive track design, travel beyond what you thought possible with the best snow performance.
APACHE BACKCOUNTRY LT TRACK SYSTEM
Designed to support the heavier loads of SSVs while delivering better traction and an unmatched flotation level.
> Defender
> Maverick X3
TRACK PATTERNS
2’’ lug and 3’’ pitch to increase floatation and traction in various snow conditions.
GEOMETRY
Aluminum slider system reduces rolling resistance and increases the contact patch.
ACCESSORIES
Customize your kit to your riding conditions with additional idler wheels, Vespel sliders and ice scratchers.
DPS MODULE
Enhance your track experience with a unique Can-Am Dynamic Power Steering module. By configuring multiple settings such as power steering
response and speedometer with the track ratio, your vehicle’s speedometer and odometer will stay true and in sync.
EASY INSTALLATION
Use of Can-Am vehicle specific mounting brackets to simplify initial track installation. The integrated design allows them to remain fitted while using wheels, making future installations as simple as changing a tire.
COVERED BY A 1-YEAR WARRANTY
DETAILS
TRACKS WHEELS & SLIDERS
The Backcountry track pattern is designed for optimal snow traction, without compromise.
The 2’’ lugs combined with the 3’’ pitch allow your vehicle to “float” over deep powder and
challenging terrain with class-leading traction.
The Backcountry and Backcountry LT use a combination of rubber over molded wheels
and a snowmobile-like slider system. This combination reduces rolling resistance, maximizing power transfer to the ground.
FRAME ANTI-ROTATION ARM
The Backcountry system was designed for one purpose: to increase the contact patch.
Composed of a steel upper section that supports lower aluminum sliders, the snowmobile-like geometry offers unmatched weight distribution on snow.
Adjustable pre-loaded spring and multiple rubber dampers keep tracks securely in place and ensure your machine’s performance. Our unique system has been improved for better performance and control.
SPROCKET TENSIONER
The Backcountry and Backcountry LT use an external drive sprocket for slip-free power transfer. Developed exclusively for Can-Am vehicles, it uses a 3’’ pitch for optimized performance in deep snow. The Backcountry and Backcountry LT use an easy to operate snowmobile type tensioner. See page 10 of product brochure for complete technical specifications and suggested pricing. Get the catalog here: https://can-am.brp.com/content/dam/canam-offroad/Track-Kits/EN_Final.pdf Visit an authorized Can-Am dealer for more details or shop online at can-amoffroad.com.
The new ProMount lineup was created for both professional operators and enthusiasts looking to take their tool kit to the next level. Designed to work as efficiently as possible, Can-Am reimagined the plow from frame to blade with its new ProMount plow lineup. There’s a ProMount for every Can-Am, plus setups for specific heavy-duty use—and a stout quick connect frame mount for unmatched utility and convenience. Made from 12-gauge steel and designed for efficient plowing, the ProMount steel blades are offered in multiple sizes to fit jobs large or small.
CAN-AM PROMOUNT STEEL PLOW KITS
These kits include: Can-Am ProMount Steel Blade, Push Frame with Quick-Attach System and Mounting Plate. The forward mounted push frame provides industry-leading lift height. Underbelly mounting plate provides the optimal angle of attack for best push strength. The low-profile mounting plate has little impact on ground clearance and can be left installed year round. In addition, the system allows you to create your own kit by choosing any plow type/length that you’d like for the push frame. ProMount Push Frames are compatible with all the blades.
CONNECTS WITH A CLICK
Attachable in four easy steps, the Can-Am ProMount plow system is the fastest, easiest way to start plowing and get the job done—minimal effort for maximum result.
1. Drive straight toward the plow.
2. Attach the winch cable to the plow using a guiding hook/roller.
3. Lift the plow until it clips onto the mounting plate.
4. Remove the winch cable from the guide. You're ready to plow.
72" BLADE
Defender, Maverick X3
715006302 · Black
715006303 · Yellow
$984.97
CAN-AM PROMOUNT STEEL BLADES
Blades available individually to create your own kit. Compatible with Can-Am ProMount Blade accessories to further enhance plow versatility (some plow accessories are not compatible with 54" plows).
72" BLADE
· Clears 66" (168 cm) when plow is fully angled.
· Blade height of 17" (43 cm).
715004474 · Black
715006021 · Yellow
$379.99
How will this promount plow system compare with the superduty systems? I just agree to purchase a 2018 left mover HD8 and wa showing to have the superduty plow installed. From what I understood the superduty plow connects in the front and quickly detaches. Does anyone think I should wait on the promount? Any help would be greatly appreciated. Thanks
It looks a lot like how the superduty mounts
Yeah it appears it is. Wonder if this is replacing the super duty or just a more affordable option? Now that I have the super duty really like the way it works.
I have a moose plow it is really strong but a bear to mount so I might switch to a superduty plow set up.
Superduty is def the easiest plow to hook up I have ever owned. Seems very well built but time will tell on that.
I have a outlander 1000 with backcountry appache tracks work great but one problem i cant turn the plow to the side all the way its rubs on the track anny option to fix this problem
Can am makes a push frame extension for the plow with track the part number for defender is 715006257. They must make one for the plow on the atv.
