A/c
Xmr0726
Has anyone been able to put a/c in a xmr. Or just any defender for that matter? I called the dealer and they were dumbfounded to the idea. I know only a limited comes with it, but why can’t you order a full replacement kit for a limited and put it in an xmr. I already have heat.
The passenger side of the motor is different on the limiteds, it would require an awful lot to make it work, including reprogramming of the ECU to run continuous when the A/C is on.  It would be much cheaper to make an XMR out of a limited than the other way around.
