I don't know about 32" but I am running 30" (in the build section).
Power can be raised a bit with a flash from MFI(in the builds section) and a clutch kit from EPI, Dalton or others will make the most noticeable difference (in the builds section). You need to get the engagement RPM up and allow the engine to increase RPM more than stock so that it gets into the power sooner. JMO
