30” tires on factory 14” wheels
Vader
2019 Defender HD10 xt…I added front forward control arms. Currently running 28x10x14 all around. Wanting to go up to a 30x10x14 and stay with factory wheels. Will this be a problem being the front wheels are 9” wide and the rear are 11” wide???
Check out my thread in the build section, same machine already had a different front end and nicely runs 30"x11x14 all around, I turned up my spring settings on all four corners and added a slight lift, no rubbing except on very uneven ground.🙂
If you have the Arched a-arms, then putting S3 springs on should do just fine for 30" on stock rims. It's what I am running.
