3" lift kit for 2023 can am defender hd10 limited
nddawg
Hi i'm new to this forum, my 2023 can am defender HD10 limited 2 door just came into my dealership, there are having
trouble finding a lift kit for it that will work. Can Am changed the rear trailing arms on the later 2023's and none of there kits will work, anybody
eles run into this problem??????
Hi welcone to the forum, its nothing new that Can Am has changed parts of the suspension, they did the same thing on the 2019 HD 10 XT Cab.
I am not sure why you need a 3" lift but there is good info on the previous machines that may help you out in the builds section.
Can Am doesn't change parts by building new ones all the time but they usually use parts from other models to make the changes, following the part numbers may help you out.🙂
